my throttle body was bypassed a long time ago. i need to replace the coolant hose from the lower intake manifold to the expansion tank. is it easiest just to pull the ac compressor out of the way a bit? the only other way to get at it looks like removing the upper intake... i really don't want to do that if i can help it.
looks like: remove belt, then remove 4 screws from the top of compressor and the lines attached are bendable enough to work it to the side momentarily.
also, anyone know where to get these style clamps? how do you size them..just measure the outer diameter of the hose you're using it on??
i found a few at lowes, but not really the right size.
