I am trying to remove the oil cooler to gain access to the transmission cooler.
The problem I am having is the hose that is connected to the oil cooler has a bolt that is used to hold the hose to the oil cooler and it is frozen. I have been hitting it with penetrating lube all day but still will not budge. If I can disconnect the oil cooler hose where it attaches to the bottom of the engine, but need a good way to plug the hole. Any ideas?
Thanks
Thanks
