Does anyone have the procedure for resyncing the windows and sunroof on a 1997 P38a 4.0 SE? I've searched rangerovers.net, but haven't come up with anything.
i believe you open the sunroof, close the sunroof, put up the sunroof, put down the sunroof, then fully open and close each window individually. hope this helps.
:drink1: O.K. no problem here is the right way to do it , you open the sunroof completely and with the switch still pressure dawn you hold it until you see in dash boar the reception of that order it makes a small noise easily noticeable , then you proceed with windows dawn and wait the same way with the switch pressure dawn until the order is memorized an so one O.K. the trick is when you do this is to maintain pressure on the switch until the order in memorized ..if you have a problem just tell me and I will send you instructions .
