1 - 4 of 4 Posts
Drewid,
Sounds like a bad ground or bad connection. I'd say check the grounds, clean, grease and reattach and then take all those bullet connectors apart, clean, grease and reassemble. I've found that a dremel tool with the wire wheel cup does a great job of cleaning these things, then use a small portion of dielectric grease. While you have everything apart, you might want to get new connectors and you might also want to investigate putting relays in for the headlamps...
Bogatyr
1 - 4 of 4 Posts
