Thanks for taking time to read this.
My 1965 Series 2A is running very rough. It also looses a small bit of power under load. It seems to have a big flat spot when I put my foot on the throttle put appears to run ok at higher revs.
This have started when I had it parked up for about 4 weeks.
I have already done the following:
Tried 2 different coils
New spark plugs and leads
New distributor (Including points and condenser)
New Carburetor kit (Zenith) as well as tried a carburetor from another LR
New manifold gasket
Adjusted valve clearances
Clean fuel filter bowl (Manual fuel pump)
Adjusted the timing
Tune carburetor with a color tune tool (Can't quite get bunsen blue color 100%)
Replaced fuel in tank
Yelled at it "Run stead ya bastard"
Never ever swore at it.
Any ideas will be greatly appreciated Thanks!
New manifold gasket
Adjusted the timing
