1 - 3 of 3 Posts
Have new OME shocks and steering stabelizer comming in for my 95 Discovery.
Any tricks ,advise, help on install would be appreciated
Thanks!!
1: it is sometimes difficult to compress the lower bushings in the back. Place a thin washer over the bushsing and tighten the nut down, remove thin washer, replace with correct, tighten. Use a die-grinder mounted wire brush to clean the cups where the bushings sit.
2: the upper rear nut can be a bear, use a breaker bar to loosen.
3: front shock tower retaining ring studs often break. Either have replacements or use lots of PB blaster.
4: front again, jack vehicle up to unload front spring so you can fit your pipe wrench between the coils to grip the shock to unscrew the lower nut-or, use the blue-tip speed wrench :D . Keep the hose handy as these are often quite greasy and burning your truck in the driveway is sure to attract attention.
Thanks
The information you provided will be helpfull, and will save me time!
I appreciate it very much
1 - 3 of 3 Posts
