1 - 1 of 1 Posts
· 1993 range rover lwb - Roman Bronze
Here is the removal of only the side mirror. In case you just need the mirror and not the whole casing....here you go:
The Classic mirror is held in by only two clips:
TOP CLIP
Auto part
and
BOTTOM CLIP
Hand Auto part Floor
Auto part
....Where my fingers are is just the covering so when you undo the two clips then the mirror just slides out.
Looking directly in front, turn the mirror all the way to the left so you see the right inside portion..you will then see a metal clip Audio equipment
Take a blunt object, preferably something soft as to not crack the mirror, then first push on the metal clip to disconnect. If not then you will be there all night as it gives tension to the clips.
Next push down on the top clip and then push down on the clip at the bottom and the window will slide out...disconnect the connections and your done. Hope that helps
1 - 1 of 1 Posts
