So how did you wire your roof light? Pic's added!
I just wired up my rear lights. I haven't received the front and I most likely won't have them before my trip but the rears came out sweet. :buttrock:
Ok so I took the pictures today. Here they are, and just keep in mind I wasn't using a tri-pod so they could have been a little clearer, but here they are:
From the front:
From the back:
The lights themselves:
I made the custom brackets out of Aluminum so I would have to worry about rush but I forgot to use primer them in a hurry to mount them so I need to repaint them but I'll do that once I get back from my trip and get the front lights:
As for wiring I ran all the wiring though the rack itself, for 2 reasons: 1) to protect the wiring, and 2) Because I need the wiring to be clean... OCD ya know
As for the power for them I installed a secondary fuse block under the hood for all my accessory add-on's I'll be doing over the next few months. Its wire with a relay so that the truck must be on for the to work but the power isn't coming from the underdash fuse block. I made the bracket from 1/4inch black plexiglass to keep it from rusting under the hood, plus its just easier to work with compared to the aluminum:
For the switch I had to use a cheap POS switch dremelled into the stock blank but I'll be installing a LR stock AUX switch later on. I placed an order but they where on back order so I hope to have that once I get back from vacation too...
Its a work in progress... :clap:
But I would love to see how you guys/girls have wired your lights and how you got the wiring into your trucks.
So post them pictures :clap: :drink1:
From the front:
From the back:
