Removing Plenum for plug wires
I've tried to fit my hand behind the plenum and cannot do anything except touch the wires where they connect to the coil packs. I moved the wiring harness but the are several tubes/pipes running along the firewall that don't allow me to grab ahold of the end of the wires. I thought I saw some directions on this forum for removing the plenum but I cannot find them now. It looks like you need to remove the throttle assembly and other stuff bolted onto the plenum, and then there are four bolts securing it. Any instructions greatly appreciated. 2000 Discovery II, 88,000 miles with original wires. I want to replace with the 8mm Magnecors I just got.
We drove about a thousand miles last weekend and the exhaust/tailpipe was growing a black mustache from carbon build up on it. I have done the Sea Foam treatments in the tank and through the intake, but I'm sure the wires need replaced.
Thanks, JDB
