It depends on the reason why it doesnt work... it needs investigation to identify where the trouble is cos it can be a wiring issue as the VSS(vehicle speed signal) to not reach the instrument pack or if it does the fault is within there and you'll need a replacement...is that the only fault you have? that's important to know cos that VSS genetrated by the SLABS ECU based on wheel speed sensors input is used by other systems too including engine management so it splits at a point
I'm going to look at this vehicle tomorrow and so far this is the only thing he has stated over the phone that does not work, i will let you know after i test drive it.
In this case make sure that the ABS, TC and HDC warning ligts are working on ignition self test(all on for few seconds then off and stay so while driving), if these warnings are not visible go away or negociate the price down below... see attachment
