Sway bar removal info
Thanks for the positive comments - a labor of love, as we all know, but one that I find to be well worth the trouble! On the sway bar removal, or installation of sway bar disconnects, here is what I have learned from a former engineer for the EAS, from it's inception through the P-38's:
IF you have functioning EAS DO NOT remove the sway bars and DO NOT install sway bar disconnects: the EAS WILL allow for full axle travel/articulation even with these connected by engaging the "extra-high" (read that as the non-user-selectable height) setting when the EAS ECU senses the need to do so. I have done a lot of rock crawling with my LWB and have felt this kick-in from time to time, but have never needed to disconnect the anti-sway bars off-road. Primarily this IS because the axle can not travel any further than what the "extra-high" setting will allow without unseating the air bladders from their pistons, un-calibrating or darn near tearing off the height potentiometers (height sensors), and causing one heck of a mess. Obviously, if you have a coil conversion, the next thing to do after converting to coils is to install anti-sway bar disconnects, which allow you to have very safe highway driving and highly articulated off-roading. Personally, I would only go with the disconnects, and would not completely remove the sway-bars, but whatever works for you... Additionally, if you have a 93-95 Classic, or a P-38, with functioning EAS, about the only suspension lift modifications you can make are to lower the top shock tower mounts (by about 2" on my model) to have much better access to the suspensions "sweet spot" - the sacrifice will be in on highway handling, etc. IF you do so, REMEMBER to recalibrate your potentiometers BEFORE you reconnect the battery!!! I plan on doing this in the fall, and will provide photos and info at that time. I did have anti-sway bar disconnects on my '89 Wrangler, with a 4" Skyjacker lift, etc, and found them to be essential for off-roading - but that, as we all know, was just a jeep. "I understand the 'Jeep thing' - that's why I bought a Rover!" - Denver Dan
