Which three?
I know that the bolt holes on the lower /outer part of the block are very close to the coolant passages, and you probably would not be able to drill and tap effectively, without causing issues. I would suspect it is just as close on the top holes, but I have never verified that.
I would recommend a machine shop at this point, before you cause damage that cannot be repaired.
