Well I was at work last night and I got a call from my wife.
We have a SMALL PROBLEM! :dunno:
The Disco II is stuck in park and will not come out. SMALL PROBLEM ONLY If, your wife didn't stop the truck half in the street" to grab the mail because it is a whole 15 ft to the house.
I told her to call the Dealer, While I raced home.
THIS IS GOOD TO KNOW
. They tell her, "POP" the piece of plastic around the shifter (pull it straight up). There is a Black colored Button on the back side of the aluminum part of the shift that you will have to push in to release the shifter. This will either fix it or it might be broken. If it is broken, there is a part you have to buy for about 30 dollars that works with a switch off the brake pedal. Keep in mind if it is broke, you can but might not want to drive the vehicle because now the brake lights don't work either.
