Stuck Tow Hitch
8372 Views 6 Replies 4 Participants Last post by  wags
Just got a LR3 HSE 2006 with OEM hitch thats never been removed. It's rusted in place. Can't find tread and I no there is one that tells how to get it out. Dam just realized it takes a key also. Well its still rusted in place. Help
1 - 7 of 7 Posts
I highly doubt it's rusted into place. They key needs to unlock it, then the green part pulls out then you twist. Many people miss the "green part pull" part and then just try to twist it.
The plastic handle pulls out then rotates about a 1/2 inch then stops. Is the key always needed or can you have it locked or unlocked ? No key for it.
I lost the key for mine. Had to punch the roll pin for the handle out, remove the handle and shave of the plastic tab so the key isn't needed. It has a been a few years so maybe some one can fill in some blanks.
If you lose the key you can have the lock mechanism removed and replaced by the dealer. When bought my LR3 several years ago it had the hitch receiver attached but there was no key. Dealer charged $100 for a new lock.
Any wags, even if it is rusted in place, a few raps on the side with a sledge will free it up.
Dealer 300 miles away told me local lock smiths can make a key useing the # on the key hole if they have the right blank. Local guy had no luck with the number and tryed to pick it, but its froze up. I'm thinking sledge.
Lock smith called said he can get a key insert for $30.00 he would drill the other out.
1 - 7 of 7 Posts
