1 - 3 of 3 Posts
For some reason the glove compartment doesnt close, according to my mom her friend broke it, and to fix it she tried slamming it harder and harder to try to close it.. ( women.. ) Anyway, I unscrewed the locking mechanism, it appear to be fine, is there supposed to be a plastic piece in the mechanism that holds the compartment closed? ( as in the part the hook goes into. )
· Magicly Delicious
yes, theres a plactic 'square' that sort of hangs down. the hook attatches to the right side of the square. hope that helps.
if all else fails, there's always duct tape! :banana:
women indeed. arent they suposed to be the more gentle half of our species? :dunno:
If you look at the receiver part that locked the door to the dash... it is screwed on... this can come loose. Make sure it is pull back forward and the screws or bolts are tightened. If not, the latch will just push the locking bar back as it closed.
Good luck... that may be way to easy to actually fix the problem but worth a look.
1 - 3 of 3 Posts
