1 - 8 of 8 Posts
Discussion Starter #1
My Discovery 2 has some good sun damage on the hood and the roof, any cheap way to fix it? Or would I just need to sand it down and repaint it?
You might be able to get away with buffing it out with a rubbing compound and some elbow grease. If its pretty bad you will need to repaint it.
Super Trooper
It's not sun damage, it's called clear coat failure. There is no fix for clear coat failure except a respray.
Colin
Administrator
So you can sand off the clear coat, with many grits of sand paper then have it re-clear costed.
Discussion Starter #5
Ok ,thanks. Anytime I try to hand wash it, the clear coat just comes off. So sanding it and getting a whole new coat is the best way then.
1 - 8 of 8 Posts
