1 - 3 of 3 Posts
SCUBA Instructor
Out of the blue this morning my rear sunroof starts making this aweful rattling sound while opening and closing. :confused
Good news is it still opens and closes. :clap:
Any thoughts on what might be causing this noise? :dunno:
Do not for any reason open or close it again until you have a mechanic who know how to repair it. if you are lucky, you may need to just lube it, if you are not you have bent or broken the lift arms and are looking at a new sun roof assembly.
Mike J.
If you're lucky, it might just be the glass coming loose. Mine does that from time to time, and I just tighten it back up from the inside. Four torx screws, one towards each corner. But it could be worse, it could be a problem with the tracks and lift mechanisms, which will need to be replaced.
1 - 3 of 3 Posts
