2006 LR3, 115k miles
This morning, my LR3, upon startup made a terrible noise that sounded like it was coming from the air compressor area. Then it went into suspension fault mode, normal height only.
I'm assuming that the air compressor is toast. Does this sound correct given the noise? I've read about the dryer bead replacement but I figure that with the noise it's probably too late to save this thing. Agree?
My main question, is that if I do order a replacement air compressor, which one do I order and any suggestions from where. I've found Hitachi, does the LR023964 part number just replace the LR015303? I've also seen the Arnott compressor as well.
I appreciate any advice regarding this matter. I've watched the lucky8 youtube vid and read some forum stuff, so doesn't seem to be too bad except for that third bolt and the back hoses, people complain. Any advice on replacement is welcome as I'll be doing this in driveway while it's snowing.
Thanks,
Wes
Thanks,
Wes
