It seems to run alot..Im new to range rovers..mine is a 98 RR..I keep it on low ride..right under normal ride & keep the inhibit switch on to keep it from raising up & down all the time..Is this normal or is it possibly leaking somewhere..I have receipts in it where land rover did replace a block on it..any ideas? Anyplace common to be looking for it has 84k on it..serviced at land rover & a 1 owner..also the tranny seems to short shift..goes 1-2-3 pretty quick under normal driving..no lights on & my snapon scanner showed nothing other than TPS at 12.9% at idle in park..checked fluid when cold & was 2 quarts low..suppose to had the 90 k service already done tranny fluid change & all..maybe didnt refill all the way? Thanks for any help you can give me
Brian
Brian
