1 - 7 of 7 Posts
Hey all i'm not so mechanically minded when it comes to cars, but i need to change the distributor rotor in my 98 freelander. is this a simple task of unbolting on and off or do i need to take more care, in other words take it to a mechanic.
Cheers
Polish and proud of it.
This is interesting .
Is this ford engine or Land Rover engine ?
How come it's not coil paks or coil on plug .
But anyway .
Do you need to pull the whole thing out of the block ?
If yes . Then yes you need to mark the position of the rotor when you pull it out , cause the gears are helii gears ( I don't know what they are called , but they have a twist to them) . So this way you can put it back in some what the same spot that you pulled it out from .
Cheers
You just need to unclip the distributor cap - do not remove leads - the rotor should then just pull off - the new one can only go on one way.
Freelandin said:
Ok, sounds pretty simple but is the whole leaving leads on thing of dire importance or just a way to leave the firing order right, because i'll be changing cap and leads aswell.
Thanks
Adz
Just to prevent confusion - make sure you mark or sketch a diagram where things go before you remove everything.
1 - 7 of 7 Posts
