I thought I would post this upgrade that I am doing for water gas tire and jack support. The first picture is how I have had them mounted for a long time.
I am in the process of inverting my roof rack (Will be in a separate posting) and extending it so I can get in and out of parking garages when the occasion arrives. SO I figured it would be as good time as any to build the rear gate.
The First picture is the way it was before I started.
The bumper was bent up on the side I needed to mount the pivot pole hinge, but I was able to bend it back into place from the side and it worked well.
Pic 2 and 3 is the pole hinge and the bumper repaired. The hinge is mounted with 2 bolts with spacers that go all the way through the bumper to the body.
As with everything else I ever do on this rig I re-purposed all of the materials to build this. I will leave the re-purpose description after the final pictures are posted.
Pic 4-5-6 I reinforced the swing out part of the gate with a 1/4-inch steel plate attached to both the bumper and the body that acts as a support as the gate swings open.
Pic 7-8 Shows the swing action.
Pic 9-10 Show both gates open at the same time. (Both have 45-degree capability)
Pic 11-12 Show the cut out of the metal grid panel to give better visuals to the licence plate and better footing when climbing up to the roof rack.
Pic 13 Is the roughed in project. I still have the additional mounting hardware to install as well as truck bed coating over all the exposed metal parts.
More to come....
Tex
More to come....
Tex
