Planning on doing the Swivel pin preloads this weekend, I note in the workshop manual, two procedures for checking the preload, one for non ABS and one for ABS systems.
The procedure for ABS systems requires the use of a torque wrench and a special Land Rover tool. The non ABS uses a spring balance on the track rod end.
Can you do ABS systems with a spring balance? Or do you have to use the special tool?
1996 Disco
1996 Disco
