1 - 7 of 7 Posts
Do you plan on putting on a conversion so you can use the CDL whenever you are off the road?
Here is a picture of the CDL linkage mount on your t/case, it can be turned with a wrench, but it is a real pain to have to crawl under there whenevr you want to use it.
Tell us more about what you are wanting to do with it.
Mike J.
Tcase
I am getting a high frequency vibration at about seventy. It feels like a driveline problem and I've checked everything else(bent rims, bad tires, air pressure, wheel balance, u-joints, slip yokes, output flange bearings, pinion bearings). So I'm kinda out of ideas, a driveshaft is too spendy to replace on a fifty-fifty chance that it may be the other one. Would certainly like to hear any suggestions though. Thanks
Need more info, year, model, mileage, and how did you check the drive lines???
Mike J.
Discussion Starter · #5 ·
Tcase
Its a '99 Disco 2 with 73k miles. I checked the drivetrain by placing the trans in nuetral with the wheels blocked and moving the shafts all directions by hand to hopefully find a worn out u-joint or slip yoke. I removed the front driveshaft and examined the double cardon joint, u-joint and the output flange of the t-case and found no fault there. The rear driveshaft was in equally good condition. I can't see a bend in either shaft, or a place where a balance wieght may have come loose. Oh, and that silly little rubber coupler is free of cracks or deformations as well. Hope this helps, thanks.
You went past the problem I think.
Do you remember when you pulled the front drive shaft and inspected the double cardan, did you notice if there were any grease fittings on the u-joints? These are usually always the problem because they can't be serviced and they fail usually taking out either the t/case or the transmission case. Well know problem for that problem, I had to replace mine at the low 40,000 mile mark and they were powdered.
So if yous haven't ben changed do so and make sure you use u-joints with zerks for replacements.
Mike J.
1 - 7 of 7 Posts
