Sensor fault???
Hi Jades007,
My guess would be a faulty water temp sensor. The sensor has a "resistor" inside that increases resistance as the water temp gets hotter. As the resistance gets higher the display shows higher temp. When these sensors break down they have a higher resistance at a lower water temp which shows a inaccurate display.
Firstly check your sensor connections (clean them up, it could just be a dirty or loose connection).
Then if you have a meter check the body of the sensor is making a good ground loop to your battery negative.
Then check the terminal connection on the sensor is showing 12-14volts. (with ignition on).
If both of these are good then its a good chance that your sensor is hooped!
I have seen new RR water temp sensors go for as low as $10 on eBay, but be sure its for the right year & model before bidding...
good luck,
Andy
