1 - 4 of 4 Posts
Discussion Starter #1
I have a 2002 Discovery and I just removed the XYZ switch and discovered that a bolt had broke. Can I test the switch to see if is working or needs to be replaced? Is it possible that it moved enough with the broken bolt to cause my problems (M&S lights on and car in limp mode and hearing a bang when shifting into gear).
I had banging when shifting down in gear and harsh when shifting up. turned out to be the pressure release valve. I put a cleaner thru the gear oil and it dislodge rubbish and blocked the pressure release valve. $1200 to get it fixed.
Maybe check that.
very disco
Lolol. It’s been 9 years it’s probably sorted
1 - 4 of 4 Posts
