So, putting my top end back together after replacing head gaskets and reconditioning the heads (resurface and valve job). While tightening the RH side rocker shaft bolts, the front bolt broke off and I had to use an easy out on it. While waiting for a replacement bolt, I decided to do the LH side. This time I set my torque wrench at 15 ft. Lbs. and tightening each bolt from front to back. I then set to 20 lbs and repeated. Then 25. Then 30. This time the bolts turned more than I thought they should for just 5 extra lbs. my torque wrench was not clicking and I broke another bolt!!
What am I doing wrong here? I'm assuming the springs are compressing and the bolt is bottoming out, but how do I correct that from happening? I'm sure I'm just doing something stupid, but help is greatly appreciated!
