Will I need to remove the oil pan to remove the timing cover? 1999 disco II 127000. thanks
450ac · Registered Joined May 29, 2009 · 94 Posts Discussion Starter • #1 • Jul 8, 2013 Will I need to remove the oil pan to remove the timing cover? 1999 disco II 127000. thanks
Disco Mike · Premium Member Joined Aug 11, 2004 · 16,594 Posts #2 • Jul 8, 2013 Sure!! Why are you needing to remove it? At your mileage, you may want to replace your timing chain set and oil pump also.
450ac · Registered Joined May 29, 2009 · 94 Posts Discussion Starter • #3 • Jul 9, 2013 coolant leaking
Disco Mike · Premium Member Joined Aug 11, 2004 · 16,594 Posts #4 • Jul 9, 2013 Well if over 100,000 miles consider the pump and chain cause they will both have wear on them.
