Ever since I bought my '95 RRC, the factory timing marks never appear when a timing light is used on the number one cylinder lead. Also, if I turn the motor by hand to TDC on the pulley the distributor never seems to point at the number one cylinder on the distributor cap either. I rotated the motor a second time to be sure, and still no luck. The truck runs and drives but the timing seems a little off.
I found some hand drawn distributor marks on the pulley that the timing light matches up with if checked with the timing light connected to the number one cylinder wire. However, these hand drawn lines make it more difficult to time the rover accurately.
Does this mean that someone replaced the distributor without setting the motor to TDC and possibly even turned the motor without the distributor in the motor before installing the replacement? Or would the oil pump gear be in the wrong orientation?
Thanks
Thanks
