It appears that the harmonic balancer or rubber mounted pulley has shifted. The large and deep groove, which I believe is the timing mark, appears to be approx 30 degrees after TDC with the timing light.
The vehicle seems to run o.k., it's just that the distributor has a large range of rotation before any noticeable stumble. Not quite sure just where my appropriate timing is or how I can determine it. Tried the vacuum style timing with same results, to big of a timing band variable. Suggestions?
