1 - 20 of 22 Posts
I cannot find a direct answer on here.
I'm in the market for some bigger tires from stock. I'm going with the 265/60-18 Duratrac.
My question is will that size fit on the stock spare tire mount or do I need to do a mod to the mount?
A direct answer will be ok. If not, direct me to the right place.
I will also be swapping out the front and rear driveshafts since they are still stock. And since I'm going with bigger tires, now is definitely the time.
I tried contacting GBR in Utah, waiting on a response from them so I can order the heavy duty shafts. I will also be swapping the rubber coupler on the rear to the u-joint.
Thank you
Administrator
I am quite sure the spare will NOT fit
I have read that some people have flipped the mount to raise it but have never tried it myself.
There are adapters on the market to space it up BUT I would question the added weight hanging on the rear door.
With the added weight, you may want to consider relocating it to a rack or inside
Administrator
Hey "max"
Did you have any complications with the flip? Wiper?
I am building a 2002 and doing a 2 inch terrafirma lift planning on putting on good used set of 275/70r18 cooper discovery. (Picked up wheels and tires for $100)
No complications. I took the wiper arm off and repositioned it because I read that you had to, but I honestly think it would have been fine where it was at. It wasn't hitting the carrier, but I wasn't sure if it would deflect down a little bit when actuated, so I rotated it over a cpl degrees to be safe. You can't tell a difference in operation.
Discussion Starter · #7 ·
I think I'll order the lifter and see how that works out first.
Anyone ever order a drive shaft from Great Basin Rovers? I contacted them but still haven't gotten a response. I'll wait until tomorrow, after that, I'll check others. Any suggestions on another place to order from?
Administrator
From "breakage experience" what should be considered the weakest link in the driveline?
CorrectionTires I picked up are 275/65r18
There may be an added load on the driveshaft or the drivetrain if you go to tires with a relatively larger footprint.
Administrator
At this point this is going to be my everyday driver and will be standard diff. .. Not a serious off-road purpose built truck
Will likely swap out the transfer case in the future to a c.d.l. Unit (I currently have 2)
Administrator
I can see added load on wheel bearings, ball joints etc.in addition to driveshafts, should not be much difference to the drive axles, c.v. Joints I'm thinking?....?
That's just a 32" tire. With open diffs you'll be fine on the stock axles, even with mild wheeling. Bigger tires don't place additional strain on the driveshafts, bigger lift/driveline angle does.
Discussion Starter · #17 ·
Thanks for the help and answers.
I have another one. I don't do much off-roading. I wanted to know the benefit of swapping the rubber coupler on the rear drive shaft to the universal joint. Is there any benefit if I don't do much off-roading. Or is it good to swap just because it's better overall.
If not, where's a good place to get a new rubber coupler, I'm pretty sure I read they were recalled at one point.
Also, a link for a good write up with pics of DIY front and rear drive shaft replace would be a big help too.
Thanks again
The rear coupling is called a rotoflex. If you have a D2, it'll be fine unless you're running 3+" of lift. Just check it every once in a while and replace it when it starts to get really cracked. They last a while.
1 - 20 of 22 Posts
