1 - 4 of 4 Posts
I have been looking into the tire choices available...I am now thinking that I will go out and buy the 215/85/R16 BFG A/T tire. I checked the write up on Brabyn's website and it seems this will fit fine to a no lift stock Classic wheel well. As well as give an extra 1" of clearance to the diffs.
ANYONE HAVE THESE - OR RECOMMEND SOMETHING THEY HAVE THAT IS BETTER??:buttrock:
Wheeler
I run BFG AT/KO 33's (285's) on my Disco & I love them. They have performed very well on the trail, in snow & ice, and on dry roads. I'm not sure about the size you mentioned fitting stock suspension though. Perhaps someone else can give you a more definitive answer. I would think you might have a little rub if you turn wheel all the way but otherwise ok.
You can also fit 255x70x16 (30.05") BFG mud terrains. They are nearly the same height as the ones you are contemplating(30.39"), but are wider.
1 - 4 of 4 Posts
