1 - 2 of 2 Posts
Car initially failed emissions throwing a p1550 i think it was for emissions air leak (gas cap) the test station said they could fix it. After being in the shop for 21/2 months the idiot finally said he could not fix it
easy to take the photo, got it back with the ecu hanging out and he admitted to having it out of the case and wrapped in a towel ( nice static procedure) currently throwing the following codes including the last one which does not exist, runs rough tach does not work all lights in dash ( hill decent trans performance brake etc) are lit
p0261 Cylinder 1 Injector Circuit Low
p0264 Cylinder 2 Injector Circuit Low
p0267 Cylinder 3 Injector Circuit Low
p0270 Cylinder 4 Injector Circuit Low
p0273 Cylinder 5 Injector Circuit Low
p0276 Cylinder 6 Injector Circuit Low
p0279 Cylinder 7 Injector Circuit Low
p0282 Cylinder 8 Injector Circuit Low
p0445 Evaporative Emission System Purge Control Valve Circuit Shorted
p0448 Evaporative Emission System Vent Control Circuit Shorted
p0650 Malfunction Indicator Lamp (MIL) Control Circuit
p0654 Engine RPM Output Circuit
p1231 Fuel Pump Relay Short Circuit To Battery Supply
p1513
p1537
p1552
p166E
About to replace the computer, any other ideas :bawling::complain:
p1513
p1537
p1552
p166E
Try resetting the codes first. If they come back, try disconnecting the main battery for 20 to 30 minutes and then reconnect it and see if it is still throwing codes.
1 - 2 of 2 Posts
