The Rave calls the two idler pulleys "jockey pulleys". 1 is located above the power steering pump, the other right under the belt tensioner. if these are the two that you are referring to.. 37ft. lbs.The belt tensioner wasn't taken off, the smaller and larger metal pulleys were removed. The jockey pulley is the pulley on te tensioner? If I'm. If I'm not mistaken. I'm lookin for those two specs.
