1 - 2 of 2 Posts
Two of the three amigos turn on at various times, no real pattern in timing. I know the ABS light works, as it turns on when I turn the ignition to position 3, it is possibly a wheel sensor? or is there another cause for this. 2001 Disco 2
Your going to have to pull the SLABS codes when the lights are on. That will take an ABS Amigo or a scan tool that has the capability of scanning the SLABS. It's the only way your going to know whats causing your problem.
1 - 2 of 2 Posts
