03 Discovery II
111,450 miles.
Problems started when broken flex plate wiped out front pump on transmission and had Aamco put a used trans in it. Shortly after I got it back I got the 3 Amigos and did the fix, replaced the both rear wheel sensors. fixed right rear slider that was frozen.
I also got an error that the scan tool said was P1591 - Rough Road Signal
Also reset the ABS errors 90 - LR output to low, 92 RR output to low, 118 LR output Intermittent, 120 RR output intermittent. and 134 Shuttle valve switch. no errors have returned
Used a friends new Snap-on scanner with the LR modules.
I also have a Transmission error 21- CAN Message, MDIND Invalid, (Flag) FTLMES.
Also when I had the transmission replaces the battery was disconnected for over a month and the key functions are gone.
Any advice would be helpful
Thank You
Ed Stephan
111,450 miles.
Thank You
Ed Stephan
