1 - 4 of 4 Posts
The fuse under the hood is good, I even changed it. The trailer is good!!!! Put it on the other truck. there is nothing to the Seven pin. Might be the ground. I will check it in the am. There might be more fuses I don't know about. Just like I found on another truck. Any help Please.
I hate to tow without lights. It is legal to do during the day in NC, I feel it's very RUDE. You can see the brake lights of the truck but not the turn signals. :confused
Choke
· Premium Member
Who installed the trailer wiring package on your truck, is it factory, does it have a back up power supply which is required on a Rover???
Mike J.
· Premium Member
Meanwhile,
Get a automotive 12v tester and another warm body to pump the brakes and do the turn signals. Maybe you popped the return ground. Check it against the chassis.
Good luck.
Same thing happens to my trailer from time to time. What I discovered was that after a few trips along dirt tracks dust gets into the plug and creates a bag connection.
1 - 4 of 4 Posts
