1 - 7 of 7 Posts
On the transmission.
There is a process to servicing your tranny, so plan on doing some reading before you drain, change the filter and refill, cause it is no real staight forward.
Mike J.
He was talking about his transmission, no the t/case.
Have you crawled under and looked/felt for it, it is the same as the drain plu on the t/case.
Can you explain the transmission service process disco mike? I'm finishing up my engine gasket swap and had to disconnect the cooler line and lost some fluid. got a filter kit already and thinking about doing the service right now while i'm at it. thanks.
PM me your tele number and I'll walk you thru it.
1 - 7 of 7 Posts
