1 - 4 of 4 Posts
Banned
I was under her tonight tearing out the rotoflex shaft so I can drop the '88 - '89 RR twin U-joint shaft driveshaft in ($100 inc shipping from a junkyard on http://www.car-part.com vs $300 for the one in the kit from AB :eek: )
I actually saw how much slack I have in the centre diff and its NOT good - I can turn the hand brake drum 40 degrees before the front drive shaft moves! (This is with the centre diff lock engaged)
Questions:
How long before I HAVE to replace the transfercase?
Did I misunderstand the issue with the early Xfer cases? I thought it was the shaft between the transmission and transfer case that developed the slack.
Is it normal to have some wobble in the rear pinion shaft - and will replacing the flange and torquing the nut down sort this out?
Twin U-joint from an 88-89???? Never heard of this, maybe you got lucky and got a double cardon driveshaft.....
Banned
No- not a double carden unfortunately.
By twin U-joint I meant with one u-joint on each end instead of 1 u-joint and a rotoflex
Banned
Discussion Starter · #4 ·
This seems to have answered itself - I got the flange in and got it torqued down - no more wobble! Just hope it wasn't like that long and caused pinion/bearing damage.
1 - 4 of 4 Posts
