Removed the rear prop shaft today.. to check on the play in the rear output flange. Yep.. you guessed it.. whatever hack had this thing apart before I bought it should be beaten about the face. I re torqued both front and rear hubs on the t-case to 109 lb/ft. Vibration is almost gone. Balancing and rotating the tires next seems logical.
