Disco II with 164K, just putted on a AB brand new short block then, week after removed tranny oil pan to get rid of ATF seepage and replaced the filter, gasket and put a new atf which I replaced @ 60k per o/m schedule with no issues, now 2 days after replaced atf , NOW D2 is hard shifting when going to stop. you can feel when 2nd and 1st gear engages.
Following recommendations put lucas in it, 4 days driving the truck but
still hard down shifting seems to softer when down shift manually, and and seems to better after lucas but STILL not normal like it used to be.. BTW the atf from the tranny was nice and clean, normal atf odor and color consistent with the mileage.
does hard shifting will go away immediately after lucas????... do I need to drive it to get rid of any air in the system or whatever...
opinions and thoughts are welcome!!
thanks!
thanks!
