1 - 2 of 2 Posts
If you plan on refitting a plastic pan, yes. This is the same process on the V8. There are countless threads on this.
If you are refitting a metal pan, you can cut the neck off the old filter after dropping the pan and slide it out, and remove the neck, reassemble with metal pan & separate filter.
1 - 2 of 2 Posts
