1 - 2 of 2 Posts
I have a 99 Disco II automatic of which the fluid and filter were changed this winter and double checked by a qualified Rover service rep last week.
When using the AC the tranny OT light will come on after a couple of minutes and stay on until the AC is turned off.
Anyone have any clew on what is happening?
trans overheat
From what I gather (and I may be wrong), the transmission overtemperature switch is located somewhere around the radiator where the trans fluid lines enter the radiator. When you turn on your A/C, heat is naturally going to rise in that area because the A/C heat-exchanger is also located in that area.
Just a guess, but maybe for some reason your transmission is already running abnormally hot, just not hot enough to trip the overheat switch; when the A/C is turned on, it adds more heat to the problem and trips the switch.
Also, search this forum with the keywords transmission and overheat. It might lead you in the right direction.
1 - 2 of 2 Posts
