2001 & 2004 Discovery Series II SE7, with AND without SAI
I need a sanity check please - TLDR below:
Background:
I picked up this '04 SE7 this year with 125K on him. It had been sitting for YEARS with a blown headgasket. I replaced the entire cooling system (all aluminum), upgraded to ARP studs, STI wires and Champion Platinum plugs, replaced the Timing gears, the Oil Pump, the P/S Pump, hoses and P/S reservoir (went aluminum there too). I need to go through and check all the vacuum lines still (brake booster bleeds when I shutdown the truck and I'm sure those vacuum lines are likely dried out etc).
When putting the front-end back together, it looks like it did create a leak in the Transmission Cooler at the joint. I am sourcing a replacement but did JB Weld the joint to keep it from leaking (worked) while I trouble-shoot. There may be a small pin prick leaking now but there's not puddle. I may need to go in and coat the whole thing to stop the drip if that's a factor. It's only 150 psi and should be fine. I think I leaked maybe a half a quart of TX fluid IF that.
Currently:
Took a bit to start the truck but starts. Once she starts and goes through the cycle, purrs pretty well but once you drop the truck into gear and try to move, it's very labored and throws the amigos.
Codes:
P0302 - Misfire in Cylinder 2 (Cylinder 2 is Bank 2)
P0733 - Incorrect 3rd Gear Ratio
P0150 - O2 Sensor (Bank 2) - new
[3] AMIGOs - new
I'm getting spark AND fuel at the plug and the plug is fouled with fuel (replaced the fouled plug with a new one and the misfire continues). I have NOT removed the upper plume yet as I'm a Vin-5.
Thoughts/TLDR:
An extended start/sputter with a P0302 and a P0733 can indicate a MAF failing BUT I had that TX leak at the cooler and I don't know if that could cause the issue with the P0733 - though I lost less than a quart and I have heard of Rovers running a quart low and never seeing a 733 or 734, but is that true? Also, the P0150 is new and aligns with the issues of the truck running rich; however, I haven't put ANY miles on the truck since all this work and the fact it fouled the plug and O2 in just 1-hour worth of idle/troubleshooting is still pulling me back to the MAF. FYI - Believe it or not, in all the years of ownership I have never had a MAF fail on our trucks - hence my hesitation.
I have a spare MAF and I ordered both Upstream O2 Sensors. Will find out about the TX cooler in the next 24-48 hours, likely. My next-steps right now are to swap the O2's and swap the MAF before I go and remove the SAI & IM BUT I would like to know if anyone else has had a leak around that TX Cooler; what codes they saw associated with such, etc.?
Background:
Currently:
Codes:
[3] AMIGOs - new
Thoughts/TLDR:
