James, is it the one by the transmission? There is a solenoid by the tranny that prevents the lever from moving to D (or R, 1, 2, 3) if the brake pedal is not pressed. I believe there is a fuse for the solenoid also. Have you checked all fuses?JamesVee said:From everyone I have talked to, it sounds as if I've got a bad transmission solenoid? Has anyone here had this problem, or know where to find this transmission solenoid or how in the hell to go about getting it fixed?
