I've been getting an intermittant P1117 code,(coolant temperature sensor) for the last few weeks that I haven't been able to fix.
Have almost all new hoses, new 180 deg thermostat, have converted dex to peak, no leaks, no drop in coolant level in the resevoir, according to my actron, coolant temperature usually sits around 190, but hasn't risen above 196. I have replaced the temperature sensor that is below the lower radiator hose, but not the one on the manifold.
Could the manifold sensor be causing this code?
Thanks,
Darrick
Thanks,
Darrick
