1 - 2 of 2 Posts
Discussion Starter #1
Hi everyone,
1993 LWB project-
The headlights were not working and I replaced the switch which fixed the problem. The turn signals are also not functioning. Anything I should check before I order the switch?
Thanks for any help,
The indicator's circuit is much more complicated than the headlamps circuit, there is a flasher relay and the MFU both involved... if you dont get any activity at all when you move the stalk both ways then that's a good point to start provided the indicators are working on hazard switch command... if they dont work on hazards either then better start with the flasher relay, presuming you checked the fuses
1 - 2 of 2 Posts
