Hi, first time user, but impressed with the site.
Has anyone tried 35" tyres on a stock defender? I have a 130 dual cab ute that I love to test out off road when i can. Down under, a lot of the tracks are so well worn and blown out that my current tyres (238/85/16, approx 32") do not give me enough clearance. (the extra long wheel base on the 130 does not help).
Some local Landy lovers have virtually abused be for suggesting such a big tyre, saying it is sacrelidge....and I respect the purist approach....
But, it is purely out of a need for more clearance.
I know the speedo will be way out, my low gearing and highway power will suffer etc, but this is only for occasional use, I run stock tyres other times and are not going more than 50km/30miles from home base.
So.....
Short version,.... will I have clearance problems, will I need a bit of body lift, will I get rubbing anywhere, will the offset of the wider rims should fix that, will I need th replace the front flares with ones that give more clearance?
Also....If I run 15" rims, is there an issue with brakes/callipers or other front end underbody gear
Has anyone been there with this?
Muchly appreciated for any assistance.
So.....
