Unknown connectors
3210 Views 2 Replies 3 Participants Last post by  redtruck12
OK...you can all tell me that I should have taken photos! Removed both front seats and centre console so I could get the sopping carpets out. Replaced the drivers' seat but have a black connector that, for the life of me, cannot see where it should go. It is in the same loom as the yellow connector (pre-tensioner?)
The passenger seat does not have this black plug. Vehicle is an 04 ES so heated and electric seats.
The passenger seat is still out and I notice that the SRS light is on permanently. Would this be because the passenger seat is not installed or because I haven't found a home for the black plug?
I have scoured the wiring diagram but to little avail.
Second, I got the centre console out and while idly sitting at the traffic lights and gazing down I saw this connector which for the life of me I cannot remember removing. :eek::eek::eek:
Or perhaps it is intended for something that my vehicle doesn't have?
(Actually even though I have made these minor faux pas, it is the first bit of 'real' work I have done on the old girl and so ever so slightly chuffed with myself.)
TIA
1 - 3 of 3 Posts
TIA
The Black underseat connector is for the driver's seat belt buckle switch (which isn't fitted to all markets).
The SRS light is on because your passenger's seat pre-tensioner is un-plugged.
The small black connector on the centre console is for the shift-interlock solenoid (which you may not have fitted).
Right Han drive I assume?
1 - 3 of 3 Posts
