Hello all, looking for some help here with an issue I can not seem to correct. My keypad unlocks all doors except the LH rear door. If I try to manually pull the sill lock it automatically re-tracks and locks itself (creepy). The only way to unlock that door is to use the interior door handle which the pops up the sill lock on the first pull and opens the door on the second pull.
If I then use the keypad to lock the doors, all the doors will lock including the LH rear door. When I try to unlock, the LH rear door will not, unless I use the interior door handle method.
The interior lock button on the front console works for all doors except the LH rear door.
I am thinking about replacing the actuator for the LH rear door but since the keypad will lock the unlocked door, that suggests to me that the actuator might not be the issue. Countless hours of research and not much out there on the correction so I am looking to the Land Rover community for help, any ideas?
Thanks
Thanks
