"Land Rover Disc Kit
For
Series I II & III Front & Back
90/100 Rear Axle & Salisbury Rear Axles
The Zeus Disc Brake kit is a simple and effective conversion to transform
drum brakes on any Series Land Rover (front and rear), or Land Rovers with
Salisbury rear axles, to disc brakes. Containing all the required parts,
fitting is simple, as it uses the familiar Land Rover procedure used to
service a wheel bearing. It is a non-invasive technique, which requires no
modification to the swivel ball housing, so no need for grinders or drills.
In fact the complete kit can be removed from one vehicle to another without
leaving any trace of the conversion. The upgrade to disc brakes requires
fitting 16" 6J wheels. These accommodate the 4 pot stainless steel
calipers, and with stronger wheels, attached with the included extension
studs maximise the benefits of the improved disc braking. More rubber
through a larger "footprint", gives better and more controlled braking,
especially in wet and muddy conditions. For more information on this kit please contact Zeus or your local distributor."
